1 - 16 of 16 Posts
So, I have 5300 miles on my car now. When I drive "regular", like to the store or to work, no strange smell, all is good.
But, if I go out and play a bit and get on it a few times, I start to have a slight "hot engine" smell in my cabin. Gave my neighbor a joyride yesterday and he even commented on it. Engine running fine, all the gauges look good, so nothing appears to be wrong.
I thought this would "go away" after the break in period, but I still have the issue (has always done this). Is this normal? Will it go away with more miles? Anyone else notice this on their car? Thanks fellas :)
do you have your a/c on? is it set to recycle the air or fresh air from outside?
the headers actually glow red if you punish the car hard enough.. that might be the burning smell.
Really? I've only seen that once an a Corvette I was breaking in for new tappet lifters running without load. That's interesting.
I know what smell your talking about, Its that break in smell. Even though you broke here in i guess that smell is going to be their when you push it.
My BMW had that smell for the first 7-8k then went away.
Wanna be show worthy.
Ive had this happen to me, While i was racing after the ambulance going to the hospital cause my grandfather had a stroke ( i know wasnt good idea, i was "in the moment") and my car started to have that "hot" smell your talking about and actually worried me pretty bad, but when i started it back up everything was fine...
2018 Mustang GT Manual
Clutch maybe?
Hmm Ill be foolin around with it today because I have been having some 5th gear "squeaking" when i rush the gears...
I will sniff around and see if i smell the same thing...
i woulda said break in period as well...but 5300 miles already! it SHOULD be broken in, but hey you never know!!
I see your mods include a Steeda CAI and Boss 302 Blue Coil Covers, that should not be doing it. Having a stock exhaust should rule out any exhaust issues. Did you paint anything under the hood or spray any engine dressing, Armorall etc?
One time I sprayed too much engine dressing and until it burned off, it gave out that same type of smell.
it sounds like when your getting on it really hard your roasting the clutch
1 - 16 of 16 Posts
