1 - 20 of 40 Posts
Finally got my car back!
Dyno'd ~375 with only 10 degrees of timing on a Eddy Dyno. It was still making power @ 5800 rpm. Ran out of fuel on my 42lb injectors, going to put in 65lb injectors next month once the motor is broken in and hopefully my Divison X Stryker fuel pump can keep up.
The P1SC is @ 9-10lbs of boost with a 3" pulley. The heads have a stage 3 port done to them.
MMR 950 5.0 Stroker
Nice bro! Hopefully ill be joining the 5.0 cammed and blown club soon! Im 2/3 there! Lol! Slowly fixing some bugs and piecing together a fuel system capable of 600 rwhp then the search will continue for a D1 or T trim! Congrats on the build! Bet its a blast to drive
Nice. Upgrade your fuel and pulley down! And upgrade that blower!
Lol, it's always something. Debating the D1 upgrade also.
I don't think I can go much lower than the 3" without slippage? Some ppl run the 2.8 but have issues.
Only 375 HP with cams and heads on a stroked motor????
A bone stock 4.6 will make ~400 with 10psi, #42s, and a BAP.
I'm thinking your setup shoud be putting down 450hp right now without issue. What am I missing?
US Air Force (retired)
What compression ratio did you go with? What cams do you have? What intercooler do you have: 2-core or 3-core? Are you running e85? I was told that 42# injectors are good to 450 rwhp.
Looking good and once you get the fuel system upgraded more youll be where you want to be.
P.s. I have to ask what radiator hose that is. ive seen it in on a couple cars and it looks like it fits so much better than stock one. Did it come with the procharger or is it an OEM ford part?
Me too.
Those 42's should be good for alot more than 375. I have them on a termi motor right now at over 470 with just a stryker pump, no bap.
That was my point #42 injectors should have more room than 375. Way more!
I have 39s on 10* timing at 388 with room to go still with a 255 pump.
Exactly again.
procharged gt
I have 42lb injectors and twin cobra pumps with a bap on 9psi running hp292 cams and a p-51 intake. 471rwhp with a p1sc @ 16 degrees timing. You will get more when you up the timing.
Sent from my SCH-I535 using AutoGuide.Com Free App
although it sounds a little low, you are also low on timing. don't know how those dyno's pull so i'm unsure what kinda power you're making compared to a dynojet #, etc...
1 - 20 of 40 Posts
