Hey guys,
before posting replies.. read the whole thing. I have been having the urge to buy a mustang with a blown motor and swap a 5.4 2v into it as a complete budget project, as in buy the project car and completely finish the swap for say less than 3,000.... just to see if I can do it and see what kind of power it will make. I am talking junk yard 5.4 PI 2v, used performance NA cams and valve springs. and piece together the rest with whatever i have laying around.
the only hurdle I see to this whole thing is the intake manifold issue, it is single handedly keeping me from committing. I found the mustang, I have found several local pi 5.4's, I have 4.6 log manifolds I can use. as well as a full exhaust, can modify stock H pipe.
options known:
1. intake adapters. which I want to avoid at all costs since they inhibit the spray of fuel causing performance and mileage to go down. (I have read what could be rumors that using ev6 style injectors atomized the fuel spray pattern better than ev1 which helps this problem... but I personally rolled my eyes at that... a better fuel misting against an adapter plate hindrance will still cause issues regardless)
2. HPS hardball'r intake. (where the he'll do I find these?! the guy dropped off the grid.. website down.... still has a FB page claiming he only uses that sinve last year but is MIA) plus finding a used one for sale is harder than finding a gold plated P-51 intake.
3. cut an edelbrock intake in half and widen it.. (I refer to as the rookie internet jockey response. ) I say that because cutting that thing perfectly in half alone is a pain in the d***, then I need to perfectly machine apiece to fit the gap, and then have it welded perfectly together. have the inside relatively smooth, AND not have any leaks.
so... anyone have any suggestions that are plausible other than saying Kenny bell 2.8 or lightning swap. or buy a tig welder and make a sheet metal intake.
hopeful that someone will have any good news other than, congrats Ryan... your idea is f***ed
options known:
