1 - 4 of 4 Posts
Stupid question. So im about to 5.4 2v swap my 98 gt, the hood on the car is already pretty f***ed can i use the stock intake from the 5.4 and toss on my plenum from the 4.6? Or do i have to get adapter plates to fit the 4.6 intake. ( dont care about looks or having to cut the crap out of my hood if needed) i wanna build this thing for as cheap as i can.
Thanks!!
Use the 5.4L 2V intake manifold and bolt the 4.6L 2V plenum/TB to it. should be fine.
If you can't, then buy 5.4L adapter plates from MMR so you can use your 4.6L 2V intake manifold.
The cheapest thing you can do is find a 4.6L instead of doing a 5.4L swap....
Other options are locating an HPS 5.4 hard ballr intake, or using a 4.6 eddlebrock victor jr. And cutting it in half, and welding aluminum in the center to bridge the gap. All ideas work just fine
1 - 4 of 4 Posts
