1 - 6 of 6 Posts
i just swapped my 95 gt motor and autotragic for a 5.0 cobra motor and 5 speed tranny everything wired up fine but car will start in gear without the clutch pushed any suggestions, the car had all the wiring for the 5 speed.
There is a jumper or something where you are supposed to have the clutch switch plugged into. Or the switch has failed on the closed position.
yeh i unpluged the jumper wire and hooked it to the switch and i switched the ecu so the switch must be bad something and thanks for the help and suggestions
and im going to put 18inch bullit wheels on it and it only has 17s on it now any suggestion on tire size to run
1 - 6 of 6 Posts
