1 - 6 of 6 Posts
From what I've gathered, this is the list of parts I'm looking for:
•clutch fork
•New release bearing
•New pilot bearing
•clutch
•adjustable clutch quadrant w/ firewall adjuster
•flywheel
•5 speed manual clutch pedal assembly
•bellhousing dust cover/block plate
•clutch fork dust cover
•shifter and knob
•manual driveshaft
•T45 transmission wiring harness
•Lower shift boot
•Upper shift boot and shift bezel
Parts I have or have coming are:
T45 w/bellhousing
OEM cable
Is there anything I'm missing?
I Need More Power!!!
Either the ECM from the Manual donor car or a tune for your auto ECM to run the manual. Everything else looks good man
Head Unicorn
You'll have to have the Auto trans shift funtions turned off in the tune.... your xcal won't do that unless you have them write you a tune to shut off the auto trans shift functions.
the driveshafts are the same, you just need a manual trans yoke.
Good info guys. I want to get the aluminum drive shaft but at least I know I could use my current one in the mean time
1 - 6 of 6 Posts
