First off, are you converting to a fox style TB or just replacing the OEM unit? Second, if you use a 75mm with the mods you have listed you will loose allot of torque. The biggest suggested use for stock intake is 65mm and 70mm if you are lightly modded. The big 75mm are for those with lots of mods [h,i,c], or with supercharger/turbo applications. I run a 70mm BBK with my GT-40/Explorer intake on mine. A spacer for a 94-95 Stang will only create a 'turbine like'/swirled air flow, which may or may not be what you want, and I do not think that spacers for 94-95's [with the exception for the after market intake elbow] don't come in different sized just stock.
