1 - 15 of 15 Posts
ook so sorry if theres another post on this or close to it, but im curious if anyone knows bout the estimated weight of a 8.8 without anything and with the internals...i found a site for a rear end and its weight but i was also told the 8.8 is lighter, i have no idea how heavy or light they are so please help me out guys....
i know darrell had a list of the weight of EVERYTHING and i lost my copy of it, maybe send him a pm, i'm sure he still has it
Free Mouth Hugs
This is a list i grabbed when darrel posted weights.
stock 87-93 K-member 58 lbs
stock 87-93 A -arms (each) 10.5 lbs
stock 87-93 spindle, strut, brake rotor and caliper (one side) 56 lbs
stock 87-93 8.8 rear axle drum to drum 183 lbs
stock 94+ 8.8 rear axle with brakes 199 lbs
stock 87-93 front spring (each) 10 lbs
stock 87-93 rear spring (each) 9 lbs
stock 87-93 seat (LX - each) 36 lbs
stock 87-93 rear lower control arm (each) 7 lbs
stock 87-93 rear upper control arm (each) 3 lbs
stock 87-93 heater assembly 28 lbs
87-93 sound dedner 22 lbs
87-93 tar paper 23 lbs
stock 87-93 master cylinder 8 lbs
stock 87-93 battery 42 lbs
stock 87-93 driveshaft 19 lbs
87-93 wiper motor and arms 6 lbs
87-93 rear bumper support 31 lbs
87-93 front bumper support 23 lbs
87-93 center console arm rest/change compartment 8 lbs
87-93 door crash braces (each) 18 lbs
Factory 92 and newer high torque starter 7 lbs
87-93 Smog pump & emissions equipment 10 lbs
87-93 Fog lights & mounting brackets (each) 2.5 lbs
90-93 air bag steering wheel 9 lbs
Ford Racing 351 ALUMINUM RACE BLOCK M-6010-C451* Billet Steel Main Caps 92 lbs
GM LS1 engine with all accessories and flexplate 457 lbs
GM LS1 engine with all accessories, flywheel and clutch assembly 492 lbs
AJE 87-93 chromoly K-member 16 lbs
QA1 87-93 K-member 26 lbs
AJE 87-93 drop spindle (each) 9 lbs
AJE 87-93 tubular adjustable A-arm (each) 5 lbs
AJE 87-93 coil over strut and spring (each) 10 lbs
87-93 8.8 narrowed .75 on each side with Mark Williams 35 spline gun drilled axles, spool, yoke, Aerospace brakes, bracing, coil over brackets 182 lbs
QA1 rear coil over shock and spring assembly (each) 8 lbs
87-93 Aerospace front brake assembly (each) 14 lbs
Mickey Thompson ET Front 26x4.5-15 (each) 12 lbs
Mickey Thompson ET Drag 28x10.5-15 (each) 23 lbs
Summit plastic drag bucket seats (each) 12 lbs
Aerospace 87-93 Mustang master cylinder kit 3 lbs
Optima 8022-091 Battery 35 lbs
Ford Racing aluminum driveshaft for 87-93 14 lbs
Grant GT steering wheel with quick release adapter 3 lbs
17x9" AFS CobraR 95 chrome 24 lbs
17x10.5" AFS CobraR 95 chrome 26 lbs
17x9" AFS 03 Cobras chrome 27 lbs
17X10" AFS 03 Cobras chrome 29 lbs
17x9" AFS 03 Cobras satin 26.1 lbs
17x10.5" AFS 03 Cobras satin 26.5 lbs
18x9" AFS 03 Cobras satin 25.5 lbs
18x10.5" AFS 03 Cobras satin 29.1 lbs
17x9" BBS Spider 21 lbs
15x3.5" Bogart drag-on fly star 9 lbs
15x7.5" Bogart Classic Star 10.5 lbs
15x8" Bogart Classic Star 11 lbs
16x7" 91-93 Mustang Pony wheel 23 lbs
17x8" Bullitt satin 28 lbs
18x9" Bullitt chrome 29 lbs
17x9" Cobra R 25 lbs
17x8" Cobra 96 satin 23 lbs
17x8" Cobra 98 satin 21 lbs
17x8" Cobra 99 satin 22 lbs
17x8" Cobra 99 polished 25 lbs
18x9.5" Cobra R 00 chrome 29 lbs
18x9.5" Cobra R 00 powerder coated 27.5 lbs
17x9" Cobra 03 satin 25.5 lbs
17x9" Cobra 03 10th anniv 23 lbs
17x11" Fikse 16 lbs
18x9" FR500 satin 26 lbs
17x8" GT 99 satin 17 lbs
17x8" Mach I 03 satin 25 lbs
18x9" Mille Miglia MM11-2's 25 lbs
18x8" SSR Integral 19.5 lbs
18x9" SSR Integral 20 lbs
17x9" Steeda ultralights satin 21.5 lbs
17x9" Steeda ultralights chrome 24 lbs
18x9" Steeda ultralights satin 22 lbs
18x9" Steeda ultralights chrome 24.5 lbs
15x3.5" Weld draglites 10 lbs
15x8" Weld draglites 13 lbs
15x10" Weld draglites 14 lbs
15x8" Weld Rodlites 13 lbs
15x3.5" Weld pro-stars 10 lbs
15x8" Weld pro-stars 12 lbs
15x10" Weld pro-stars 14 lbs
15x4" Centerline Convo-Pro 9.5 lbs
15x8.5" Centerline Convo-Pro 12.5 lbs
15x4" Centerline Tel-Stars 12 lbs
15x8" Centerline Tel-Stars 16 lbs
15x7" 99 V6 Mustang wheels 14 lbs
17x9" Wheel Replica Bullitts 23 lbs
17x9" Wheel Replica Bullitts chrome 24 lbs
17x10.5" Wheel Replica Bullitts chrome 25 lbs
16x7" Crown Vic oem wheels 25 lbs
18x8.5" BBS RK (Silver) 19 lbs
18x10" BBS RK (Silver) 20 lbs
16x7" GT Waffle wheels 19 lbs
17x9" Konig Villain wheels 21.5 lbs
Free Mouth Hugs
Yeah for each one, HAHA we wish the set would be that light!
Discussion Starter · #12 ·
well i guess thats not bad yet, but i dont care for chrome newayz, im getting the bullet style from AM with the black center and polished lip so but with as much hp as ill be goin with i wont have a prob with weight just traction lol
Yeah I saw that It's just because Im so strong..... lol, good find on that list
Discussion Starter · #15 ·
well, i been lookin up stuff and if anyone wants to know, obvsiously jegs and summit have moser, competition engineering and strange rear ends that are fabbed and lighter, but racecraft has one thats nice for a grand made of mild steel and weighs with all options the site gives you at 65lbs so figured with locker axles and fluid just over 100lbs possibly, which imo thats huge weight savings for mass
1 - 15 of 15 Posts
