1 - 3 of 3 Posts
some guy is selling the rear end from his 84, it has
Auburn differentials, 373 Ford Motorsport Gears, 31-spline Moser Axels, C-Clip eliminators.
the problem is its a 4 lug, so if I wanted to convert it to a 5 lug would I need new axles? or could I use parts from my rear end?
thanks!
You realize that rear is over an inch shorter on each side, don't you? That could cause you some fitment problems with your wheels. So no, you can't use your axles, they're too long.
So in the end no it is not worth it. You would spend less and have less of a headache putting that stuff in what you have now.
1 - 3 of 3 Posts
