1 - 4 of 4 Posts
just wondering if anyone knows the serpintine belt i would use to bypass the air pump on an 1985, 302 carb gt?
or how i would be able to?
Take a piece of string and try out some routes. If you find one that works, measure the string and go to your local parts store and ask for a 6 rib belt in whatever length you measured. If it is too big, go down an inch or vice versa for too small. 6 rib belts pretty much come in every 0.5 inch increment.
do i measure the length of the string used or half of that when it's in a circle if that makes sense?
route the string just like you would route the belts.....and then just measure the string
1 - 4 of 4 Posts
