1 - 5 of 5 Posts
Well's there's 2 humps and if you only drain the back 'hump' then of course there is a small amount of oil in the front one still.
I bet most people just drain the rear.
Ok thanks. I infact usually just pull the one plug and no not just the one in front;). The reason I ask is I am doing a motor change and wonder if I can just use a "less expensive" one from sleazebay without the front hump.
Im pretty sure the single sump pans wont clear the k-member. they were made for other body cars or trucks. I beleave the rear sump pan i have is for a late model truck.
1 - 5 of 5 Posts
