OK, to start I had to replace starter, while I was at it I went ahead and did a tune up on the car. I pulled the wires off before I even thought that I didn't mark them.
From what I have found the distributor should be wired counter clockwise.
Engine is
4 8
3 7
2 6
1 5
From what I found the firing order is
1 3 7 2 6 5 4 8
I have spark at the spark plugs and coil is putting out plenty of power. Car was running fine before I jacked with it.
Now all it does is turn over never fires.
Was wondering if anyone can confirm I have it wired up right. Or is there another possibility for the firing order. I am not 100% its the HO engine so I don't know if the firing order is different.
Would like to get this fixed before I replace water pump and thermostat.
Any help would be appreciated.
Thanks!
Ray
Engine is
4 8
3 7
2 6
1 5
1 3 7 2 6 5 4 8
Thanks!
Ray
