You cant do it, call your maf company with the part numberhow do i go and calibrate the maf and the 24"s and what should i look 4 on the heads?
Size doesn't matter.. you can get either size calibrated for any size injector so you can't go by that.Hey Should I Have A 75mm Or A 90mm Maf I See That 75 Mm Is Set Up 4 19lb Injectors 90 4 24lb Injectors I Think
