1 - 3 of 3 Posts
So my 89 has pretty much a full 98 SVT COBRA suspension swap and I might have gotten the wrong size front sway bar bushings, but the mounts destroyed the bushings in about 2 weeks. Any help on this topic?
Resident Know-it-all
So u are running the later model swaybar on your fox? Which brackets did you use? The fox or the 98? I'm contemplatung this on my coyote swap fox I'm doing.
https://lmr.com/products/Mustang-Sway-Bar-Size-Guide
The Sn95 sway bars are wider end to end than the Fox and the mounts bolt to the framerail itself, while the Fox mounts bolt in board of them. I have read that some fab work will be needed to use the Sn95 under a Fox, relocating the brackets, i believe. The Sn95 sway bar brackets hang lower as well (they are longer).
1 - 3 of 3 Posts
