1 - 13 of 13 Posts
i got a 89 5.0 with some engine mods done to it and i can not for the life of me get the check engine light off. Codes showing up are koeo 15 and 63, koer 63 and 98, no balance test will work. 63 states that tps value to low but i checked it multiple times and it is fine but cant get it above .87 with drilling out the holes (some).I have also checked the full voltage of power to ground and im getting 4.98 and i think it supposed to be 5? Also car is burning very very rich also i can hear the fuel in the pipe pop if i hit the gas. I will get a list for you guys of my engine mods and maybe you can help me with some bottlenecks i may have here on the motor also because this thing doesnt run as well as what i think it should.
thanks all
Discussion Starter · #2 · (Edited)
ok so i have got my paper work out and i did have someone build this thing so im kinda sitting in the dark on a few questions to what i have with the cam im thinking that the cam is a procomp steel with 3.00 stroke but here is what i have found so far
keith black flat top piston
strike force heads
gt40 intake
hooker equal length headers
70 mm tb
still trying to figure out if i got stock maf is there anyway to see if i do or if i have an upgraded one?
i would really appreciate some help on this with seeing if there is any bottlenecks and helping it run right. I believe there is 19lb brown top injectors but one is a blue top and i dont know if its a replacement or another size? also what kind of power would you expect this thing to make. thanks in advance
thank you for replying and that is exactly what i thought and that would be explaining my rich condition im smelling so far lol one problem solved
what size injectors would you guys put in this thing because obviously i have to replace one i mine as well replace 8 with the right ones
I believe that injectors with brown tops are 42lb injectors, i may be wrong? If so, that would be causing your running rich problem. I would replace them with 24lb injectors.
In all honesty, if they guy was half assed enough to put in one oddball sized injector, I'd wonder about the rest of the build. Those heads are no good from many accounts I've seen. Some get lucky and have no issues, some wear out valve guides and drop valve seats. They flow a lot for what they are, but flow numbers don't mean much. You are probably better off with a full set of 24's on there because even crap aftermarket heads will make more power than stock e7 heads.
As far as what you were mentioning with the cam, you're confusing the cam with the crank. If you've got a pro-comp crank, the quality is going to be as good as those heads. Substandard machining and metal used to make the parts is their M.O.
Post up a pic of your MAF and we can tell you if it's stock or not.
maf
dude i can not figure out how to up load my maf has these numbers on it :sorry
abcd
ford
airflow --->
ftzf-12b579-aa
afh55-03b
oe16
that is the best i can do i have tried to resize images and cut size with no successful upload
1 - 13 of 13 Posts
