1 - 2 of 2 Posts
93 gt 5speed.Ok was driving and car acted like it wanted to die. Pulled over and I died. Went to start it and the ignition switch was loose as hell. Upon inspection I found the part where the harness plugs under the switch came apart. So tows it home and got a new one and no power to anything. No gauges or fuel pump nothing. Notice no hazzards or signals or brake lites either. All fuzes are good. Only things working are headlights horn and dome lights. Where do I start. I drove this everyday for a year and now this. If I can't figure it out it gonna get parted or sold for $1000.
Make sure you have power coming into the switch and out so you can eliminate that as the issue. If not then you need to follow a wiring diagram to see where the main power into the ignition is sourced. Should be a yellow wire out 12-10ga. Might get it's omph from or through the alternator.
1 - 2 of 2 Posts
