The PIP sensor was my first guess but you replaced the dizzy. BUT, what brand distributor? Is it a rebuild? A lot of them use a generic PIP sensor that can be hit or miss when it comes to reliablility. And what brand TFI? They can be just like the generic PIP sensors. Hit or miss. Did you check your codes again after it cut off the last time? What was the last thing you did before it started doing this? Is there any hesitation before it shuts off or does it just flat out die? Whats your fuel pressure? Does the pump prime every cycle? Lots of questions, but it will help us narrow things down.
If you dont have any PIP or TFI codes, it could be the coil cutting out. I wouldnt rule out the PIP or the TFI just yet tho.
