1 - 18 of 18 Posts
Wished my car was done.
I got a question, i'm not new to mustangs but i am new to 5.0. What can i do to my 94 GT to gets some more power and a lil better fuel mileage?
I meant like getting it tuned or something. Would a CAI help any? Turn the ignition timing up? I am not trying to make a super fast car out of it. Just give it a little more juice.
CAI may help a little bit.
I would just take out the rubber silencer on the air filter part. Gives significantly better airflow.
The timing won't really do much either. The timing changes depending on RPM and driving conditions anyway.
Some cheap ways to improve gas mileage are weight reduction, change the fuel filter, use fuel injector cleaner regularly, and switch to a synthetic/semi-synthetic oil. Cleaning the MAF helps as well if it hasn't been done in a while.
Alright, well i'll check the MAF meter one day this week and see if it dirty.
Would having the EGR block off and the smog pump disconnected affect my fuel economy?
Resident Headbanger
No, but getting rid of both with associated pipes/valves would clean up the engine bay quite a bit.
Easy things you can do to gain some power:
Remove air silencer & MAF mesh screen
Port MAF sensor housing
Advance ignition timing
ASP underdrive crank pulley
Short belt AC/smog pump bypass
Some weight reduction and a 3.73 axle gear swap will also help in the performance department and not have a negative effect on gas mileage.
Alright, i'll check into that. I ran to one of the former owners of this car and he told he put 3.55 gear in the car, but didn't calibrate the speedo. How hard will it be to fix that?
your fuel economy will go down if you delete your EGR, and you will gain no extra power, the only benefit you will see, is a cleaner engine bay
Late modell restoration sells speedo gears for a few bucks and it only takes a few minutes to put in.
Discussion Starter #10
Is there a way to fix that, like having it tuned to operate with out the EGR and keep from lowering fuel economy?
So i just have to change the speedo gear going in to the tranny correct?
Also which gear exactly do i need for having 3.55 gears
No, you're not allowing the unburned gasoline back into the system, and therefore you're just wasting fuel.
23 Tooth
I think the EGR only functions at idle and low rpm.......At full throttle it doesnt do any thing, i do believe, but i could be wrong......there's some thread in this section where fogged306 explained how it worked, but i cant remember the details
Discussion Starter #13
Damn it.
Unburned gasoline, wouldn't the car have to be running real rich for that to happen?
And thanks, i'll be getting that on my way.
I have read some like that about how all that EGR mess works in the past but thats done long gone from my brain. I'll try and search for it again.
I think it went some thing like this.....
the EGR fill up cylinder space with burned exhaust gases which normally would have been filled with air/fuel and thats where the gas saving come from.....but when you get on the throttle the EGR stops putting exhaust gasses in, and only puts in air/fuel
Its some thing along those lines
Basically.
Sounds like a reverse turbo :D.
You will gain a little power from removing it. But not a lot. Less parasitic loss is always a plus.
Basically.
parasitic loss? doesnt parasitic loss refer to things like water pump, or fans where the drag of using them loses power? I'm unsure if an EGR would fall into that category, but i could be wrong
if the egr only works at idle and low rpm, then i dont think there's any power to be had....at that range you dont need power, removing the EGR would only cause lower gas mileage....The car using more gas at idle would be pointless
Resident Headbanger
The only thing you gain by removing the EGR is some underhood space to make removal of the no.4 spark plug easier. Removing the smog pump plus pipes/valves has far greater benefit.
Oh. I was always under the impression that the smog pump creates a good deal of drag on the motor. I guess I will be leaving mine in then. :sorry
1 - 18 of 18 Posts
