1 - 4 of 4 Posts
I'm pulling out my T-5 transmission to change out the clutch for a ford racing one as well as changing my output shaft seal since I recently found out it was leaking. Is there anything else I should swap out while I have the transmission out?
Agree with the rear main seal.
On a side note if you have 3.73 gears or another aftermarket ratio installed already, I'd swap out the output shaft "drive" gear in the transmission for a yellow gear and then the VSS gear for the red gear so that you're speedometer is calibrated properly. This is also good if you plan on changing gears later.
1 - 4 of 4 Posts
