Hello, I have a 1995 GT that sufferers from an overheating issue. I have tried everything I can think of to fix the issue to no avail. I have a brand new Mishimoto performance radiator with a Mishimoto performance fan, I have all new mishimoto hoses, a brand new aftermarket thermostat housing, a brand new 180 degree thermostat, and a performance water pump. Still no luck at this point. I didn't trust the car to run the fan on its own since it seemed to be coming on late so I wired it directly to a switch. All that accomplished was to slow the rise in temperature but it still would never stop climbing. To make sure it wasn't the gauge I got a AEM water temp gauge with stand alone sensor that I mounted in line with the upper rad hose. New sensor and gauge confirms cluster gauge was mostly accurate. I tried bypassing the heater core in case there was a blockage there but still no change. I cut out the center of the thermostat for constant flow and saw no difference. I tried burping the system multiple times to remove any air bubbles but still nothing. I also tried messing with the ignition timing which didn't help at all. And just tonight I did a head gasket test by checking if there were any exhaust gasses in the system and it confirmed there was none. At this point I have overhauled the entire cooling system but still the engine will not hold a temperature. Regardless of driving or sitting idling the temperature will climb. I had gotten it up to over 250 once just trying to make it home from work. So if anyone has any ideas or tips for me id greatly appreciate it as I cant think of anything else to try.
