1 - 4 of 4 Posts
I came across a deal on an 80mm maf meter and 24# injectors. The only problem is the meter has the 6 pin connector for the obdII 96 car. Is there anyway to convert it to the 4 pin connector on my A9L car?
Ill just make a CAI, does it need any recalibration or just get the adapter and hook it up? it is for the 24'ers.
you have too look up the MAF transfer function table voltage. If the one from the donor MAFs computer matches the one for the A9L it will work. If the voltage is off you'll have some drive ability issues.
1 - 4 of 4 Posts
