1 - 5 of 5 Posts
Bought an after market hood need to adjust the latch to suck it down, I have seen ways for later models but not for a 96 Cobra hood.
Screw down the rubber bump stops to suck it in more..... if they are already screwed all the way down and you need more i have no idea what to tell you
i also wonder about this besides hood pins. At 120 or so my hood starts shaking and it makes me real nervous so I let off. Mine is adjusted as far down as it will go. Even to the point were its tough to pull the hood pop but even this tight I still get the "flutter".
I got it working like a charm ! I did the washer under the torx screw trick and I cut the 90 degree bend off on the strike plate on the hood. No slamming to close just push it down and I am good to go.
1 - 5 of 5 Posts
