1 - 12 of 12 Posts
So I'm trying to take out my trans to get a new relaese bearing in. I have a chilton manual. It says that, after removing the exhaust, etc., to take out the 2 bolts on the right side of the trans and the 3 bolts on the left side. then move the trans back until the shaft is clear and remove it. took out the 5 bolts and it is still attached. Won't move at all. Am I missing something?
I Have A FLATULENT Butthole.
Have you disconnected the clutch cable? I wouldn't think that could prevent it from moving, but it certainly wouldn't make it any easier. Are you sure all the bolts are removed? I though there was more than five bolts holding it to the engine, but I could be wrong.
Sent from my DROID RAZR HD using AutoGuide.Com Free App
Carport Built
There are two studs on each side of the trans also the slide into the block. I had to pry on mine a little to get it separated.
I am wanting to say that there are more bolts on that transmission. I think there are 6 or 7. Look it over really well and make sure that they are all out, if so, pry on it a bit.
ya cable is off. It has only been a year since i had a stage 3 zoom clutch put in. they must have used a cheap release bearing cause it is shot. The bearings were falling out of the bottom of the trans when i was messing with the fork... It wasn't slipping at all' so hopefully it is just the release bearing. I pried on it a little, but not hard. Since it has been such a short time since it has been out, I assume nothing should be seized.
in the chilton's it specifically says there are 5 and has an illustration that shows them with arrows. If there are more, I can't see them and would be impossible to get to.
Carport Built
You won't hurt it bud just make sure all the bolts are out, get a flat head and pry that bad boy out. It has two studs so it fits snug.
Haha, ok I'll give it a little more. done for the day, started at 8am. I'll be back on it tomorrow after my weld test. i'll let you guys know. thanks for the advice
Should be 7 bolts. Dont forget the two on the bottom that attach the spacer.
What about the 2 on the top of the transmission? Did you get those two?
Discussion Starter #12
I did. I was missing the 2 top ones.That chilton manual isn't as complete as I expected. They get you close though. Got it all put back together on christmas day..... Heavy duty ford racing release bearing. Took me 5 min to put it in then another couple of hours to get it all back together. Thanks for the help guys.
1 - 12 of 12 Posts
