1 - 6 of 6 Posts
The last few times I've driven my car, it will "click" the first time I turn the key and start up normal the second time I turn the key. The "click" is the same sound you get when you have a dead battery, but it is just clicks once. Any ideas? Starter or starter solenoid on the way out?
^ +1. Start with the simple things first. Hopefully its not the starter, they are a B to change!
Start at battery terminals making sure they are clean and tight. Then work your way towards the starter.
I need to buy a new cable. It has the clamp-on style terminal now, which I don't trust. I cleaned and tightened them the first time this happened. The battery is fine. Like I said, single click first try, starts normal second turn of the key.
Thanks for the quick responses.
1 - 6 of 6 Posts
