1 - 12 of 12 Posts
I know brands such as magnaflow make catted X-pipes, with one cat on each side. I'm pretty sure those are SUPPOSEDLY 50-state legal. I would recommend that
Rollin' 18/ pushin' 2
If your state just plugs it in to check the emissions then you can get a set of MIL's to trick the computer and you will be fine. If they do a visual inspection of the emmissions system then you probably want to go with the high flow cat setup. Unless you got a friend that does inspections......
well i didn't know if ALL made them, and magnaflow is the only one i could name off the top of my head.
IF i got a catted X it would deff be magna though :D
1 - 12 of 12 Posts
