1 - 20 of 22 Posts
Hello,
I have a gauge cluster from a 99 cobra for sale with ~100xxx miles. I bought it last summer intending to put in into my 2003 V6 mustang, and bought a 99 because I liked the bluish backlit gauges.
When I tried to install it, it caused my battery to die, because it shorted my defrost switch circuit (the 99 was set up for a defrost switch next to the cluster, rather than the 01-04 double din under the radio setup. After looking at the work involved to make the 99 internals work, I opted to buy an 01 cluster and switch the face plate.
This means that this cluster is set up for a 99 (defrost switch wiring, etc.) HOWEVER IT HAS AN 01 FACEPLATE(the numbers light up greenish)
If you are simply using it to replace a broken/malfunctioning 99 cluster, you can easily swap the faces. If you are using it in a cluster swap keep this in mind. The letters ARE NOT blue, but more of a green, as it has an 01 face with the green film. Other than that it is complete working order. I payed almost $200 for each of the two clusters and since I have modified this one I would like to as $150 OBO + shipping.
PM me, or text me at 772 three-two-three 3969 if interested. I can get pictures as well, (I don't have any currently since the part is at home in FL and I am at work in IN)
I don't mean to be a dick and hijack the thread, but I've considered switching clusters in mine, what is necessary to disable pats?
I had BAMA turn it off in the tune, it took them all of 5 minutes to send me a tune revision. The theft light blinks a bit more than it would with PATS on but it was free since I have tunes for life. Any tuner should be able to do it without issue.
Anything else, let me know. And if you are interested in the cluster shoot me a PM
ttt
ttt, still for sale
ttt
ttt, someone has to want a nice whiteface, 160 mph gauge cluster. They look amazing!...
ttt
Discussion Starter #9
ttt
Discussion Starter #10
ttt, lets make a deal
Discussion Starter #11
ttt
Discussion Starter #12
ttt
Discussion Starter #13
ttt
Discussion Starter #14
ttt, no reasonable offer refused
Discussion Starter #15
ttt
Discussion Starter #16
ttt
Discussion Starter #17
ttt
Discussion Starter #18
ttt
Discussion Starter #19
ttt
Discussion Starter #20
ttt
1 - 20 of 22 Posts
