1 - 5 of 5 Posts
· Registered
What motors can fit a 99-04 mustang without cutting the firewall or getting rid of the factory K member? I have a 99 base model that I'm taking the v6 out of and I was thinking about a 302 but I'm curious as to what other engines will fit that can make 450-500 crank when built.
· Super Moderator
It depends on how much money you have. Most motors will fit without having to cut the firewall.
· Super Moderator
With that in mind you’ll have to research and decide which way you want to go. Most ford engines will fit no problem. Whether you want to go old school pushrod or new coyote or Godzilla is up to you.
· Resident Know-it-all
Coyote and either a procharger or turbo! Go with a gen 2 F150, put deletes or use Gen1 timing components, replace rods and pistons, make 1k hp or more. Easy peasy.
1 - 5 of 5 Posts
