1 - 4 of 4 Posts
Hey guys, so I just recently joined the mustang group. I now own a 99 mustang with a 79 302 in it with the c4 trans. all though the automatic is nice and al I have been reading that a t5 manual transmission will bolt into the 302 with a bell housing plate. what would I need for a flywheel, clutch, and adapter plates to make work?
Wheel Tire Car Vehicle Grille
Vehicle Hood Car Automotive battery Motor vehicle
Super Moderator
You should be able to source the pedal bracket from any 94-04, the t5 will need to come from a 94-95 gt or 94-04 v6, along with all the other hardware.
Super Moderator
The bellhousing bolt pattern is the same for all 302’s and 3.8 v6’s. The only thing is you can’t use a fox t5 because it is shorter.
You can use any pressure plate as long as it’s for the same spline count as the t5 you get.
1 - 4 of 4 Posts
