1 - 9 of 9 Posts
Hey guys, yesterday somehow my radiator cap was loose so when i heated up all my coolant went boiling out, no worries on that because i was only in a residential area so i pulled over and filled up with water.
yesterday my a/c would blow like normal but for some reason today it will only blow out the defrosters or the floor, anyone had this issue before?
all help is greatly appreciated, thanks
Head Unicorn
Bad blend door/broken blend door etc., prepare to pull the dash to get to the box. It sucks.
great, i truly dont wanna pull that dash that would ****in suck, where do i get a replacement. i wanna check to make sure its not just a vacuum line or something but im not quite sure which ones out of all the lines are exactly for the a/c
open up you hood and then towards the drivers side there is going to be a line... make sure its connected, i used duct tape for my old mustang... works perfectly
Ducting probably came off. Pass side. Look up and make sure that it is attached.
vacuum line most likely, but timing is weird coincidence to your other problem
yeah its a weird coincidence for sure. figured i would mention it though just in case it was somehow related.
some of you are saying lines are on the pass side, some are saying drivers side.... which is it?
1 - 9 of 9 Posts
