Just wondering if anyone has experienced this and might know the issue.
It's been 90-100* the past few days here and I have noticed when the A/C is running the motor feels like there is a huge load on it once it gets up to operating temp. Cold start the engine drives fine, but once it gets warmed up the throttle becomes really delayed in lower RPM's. I'll push the throttle down 75% in 1st gear from a stop but the car accelerates like I only gave it 10% throttle until about 2500 RPMs then the motor wakes up. Also if I don't rev it to 1500-2000 RPMs applying the clutch the motor will die from the load. I have feeling the compressor is causing all the issues because, If I turn the A/C off the engine responds just fine and has all it's power back.
Just wanted to see if I'm on the right track before I start buying new A/C components.
