1 - 12 of 12 Posts
Yes I know, I should use the search feature, I have but my problem differs a little. First I will start off with what I really need to know, what's the best way to adjust/aim my headlights? against a wall 25 feet away? an empty parking lot? etc. Anyways, I was trying to adjust my lights last night right after I put my new HID's in and I think I stripped the adjusting part on the right headlight, the screwdriver was all screwed up and I didn't notice cause it was dark and I think I went too far and stripped it, so is there any way to adjust it now that I broke it? Do I need new headlights? is there a way to make a new part where I put the screw driver? Sorry for the long post, thanks guys.
I dont know about stripping it out and whatnot but what I did to adjust mine was tighten them all the way down (will be set up really high) carry an allen wrench with me, and I turned them up a few turns at a time as I saw needed and eventually were adjusted well enough for me.
Just make sure to do the same number of turns to each headlight...
i hate ford for making the adjustment screw plastic....hmmm try to adjust it with a sharper philips head...something that can dig in and grip :yes
Damn that's a shitty situation you have there... You may be able to do something similar o what mike said, could use a knife and kinda dig into the plastic and rotate it that way..? That'd suck to have to buy new lights
Yeah sometimes ford doesn't think to well... I think I might try your guy's tricks tonight (the knife, a sharper phillips head) then if those don't work I'll try the bolt. And if all of that unfortunately doesn't work I will probably have to buy new headlights because I think it's stuck in a bad adjustment right now, how much are those retrofit headlights codycat? and do they look nice, and not scatter HID light as bad as the stock housing?
KCCO
R3dFyre02 apparently just sold those lights between yesterday and when I just checked a couple minutes ago, but he make's custom orders. Mine were around $350 if I remember correctly (I ordered the new housings separate) but well worth it. It is not even fair to compare these to HID bulbs in stock housings. Check out his write-up on how he made them http://www.moddedmustangs.com/forum...ru-hid-projectors-into-my-stock-housings.html (he has refined the process since this original set, as you can see by mine) and you can also check them out on AllBlakeverything's car here: http://www.moddedmustangs.com/forum...tang-projector-retrofit-thanks-r3dfyre02.html
Also, I will be starting a new thread momentarily with a bunch of pics of the whole build of mine from R3dfyre! :D Any more questions, don't be afraid to ask me or him
Discussion Starter · #11 ·
Think I might be ordering a kit from him soon codycat thanks for the info!
1 - 12 of 12 Posts
