I want to put some DRs and wheels on the back of my Saleen. What I am looking at is the car is lowered from saleen. It has 20x10" wheels with 275 tires, they are 26" inches tall. I want to run a 275/60/15 (28" tall) on Weld Pro Stars but the largest BS they have is 6.5. I dont want the tires to rub the inner wheel well which is the reason for the 6.5 BS. push them out a little bit from the inner well. To keep them from rubbing the wheel well lip I was going to use this air bag kit that goes inside the rear coil spring. I used one of these kits on my 87 GN for the same thing. FULL THROTTLE SPEED - Air bag kit for buick
Im pretty sure this combo will work, Draglites with 15x10 7.5 BS and a 275/50/15 (26" tall) but I want to use the larger tire.
Help!!
Thanks
Help!!
Thanks
