1 - 20 of 20 Posts
ok i just finished up my taxes and looks like in 2 weeks i get to dump $1k into my beast, $300 is reserved for my trans rebuild im doing, so $700 left obviously...
im open to anything, and dont have many mods
i found subframe connectors for $50 does that basically mean they are **** or is that an ok part to go cheap on, if so what should i look to spend on them...
itd be nice to get a bunch of little **** but like i said im open to whatever is the best thing to do
subframe connectors, exhaust, gears, intake manifold just to name a few things you could do
thanks i guess im saying what would you guys do if you had $700, want to spend it as wisely as possible.
sorry i should have added i plan on doing a h/c/i combo in 09 or 2010
nitrous
I agree with baine, subframe connecters $80-115, gears and installtion $450-500, plus shipping and a couple tanks of gas.
I vote WHEELS
ok gears it is then, so will i have any luck finding a rear end with gears in it, or is it cheaper to just put gear in what i have
finding another rear end would = used gears anyway.......i would definately say just so with gettin gears for your car.......
Discussion Starter · #12 ·
i bought my used 3.73 posi rear end for 200 it was a good find, then another 250 for control arms i just need some good tires and wheels and ill be in business.
would be nice if i could find one that cheap, if anyone has one let me know if your close to northern indiana over by notre dame ill buy it
Discussion Starter · #13 ·
5spd : 3:90
aod: 4:10
either or. good mod for you. you'll notice a difference.
I found a set of 3.73 on ebay from a guy who worked at ford and had a brand set around with bearings and shims for like 140 so I would look around ebay and at some other shops and stuff.
Discussion Starter · #16 · (Edited)
ok my local speed shop said $200 for richmond 3.73's and $350 with any extra stuff i might need to install them, sounds good to me what about you guys
so is it 200 plus 350 or wat......or is 350 the total price for everything including instal
Discussion Starter · #18 ·
dang......thats seem expensive but i guess its not too terrible......
Message
you might ask how much they would charge just for labor
Discussion Starter · #20 ·
Message
i even tried all three speedshops around me this was the cheapest, i wish i could find cheaper but i thought it sounded about right
1 - 20 of 20 Posts
