1 - 20 of 30 Posts
Rebel Of The Sacred Heart
Well I thought some of you might like to read about a little paint theory. So i figured I would start a thread and type some and ill add more to it when i get time.
Also if there is anything specific you would like to read about, just let me know.
You can break your paint jobs down to three catagories: undercoat, midcoat, and topcoat
undercoat: etching primer, primer surfacer, epoxy primer, sealer, pretty much any primer or adhesion promoter. Your undercoat is what goes ontop of
bare metal or over the properly prepped previous paint, bodywork,etc... and it gives you a uniform coat that is a uniform color to apply your color ontop of.
midcoat: base coat, pearl coat, kandy coat, metal flake coat,etc... Your midcoat is going to be what ever goes ontop of your primer and under your clearcoat
Topcoat: The topcoat is the final coating in your paintjob, the clearcoat
So a little about the different types of undercoats and what some advantages and disadvantages there are associated with them.
Etching primer: A primer that is desinged to go over bare metal. It has a high acid content and uses it to etch the metal and conditions it for increased adhesion, and will help prevent corrosion in the future.
It is recommended to use an etching primer on galvanized and stainless steel to get the maximum adhesion for the rest of your coats. However you dont want to spray your basecoat directly ontop of etching primer.
You always want to spray a sealer or primer filler then sealer before moving on to your basecoat. And self-etching primer is not really a "sandable" primer.
Primer-surfacer: There are a few types of primer- surfacer availeble such as lacquer, enamel, and polyuerethane enamel. They all are a high-solids type paint, that is desinged to build up the surface, fill minor imperfections such as sand scratches or pinholes, to further refine and finish bodywork, and provide a sutible surface for sanding. However primer surfacer usually has to be sanded before proceeding, unless it is a wet-on-wet aplication. That is why if you dont need the filling properties of it, it is best to just use a sealer before the basecoat.
Primer-sealer: Sealers are what you use to prepare existing finishes, by increasing adhesion, making it one uniform color, isolating any problems on the old finish underneath the sealer. This primer can also be used in a wet-on-wet manner.
Most paint companies have tintable sealer lines, which helps create hiding and correct color in few coats of basecoat.
Epoxy primer: Epoxy primer is a very good primer with all around good characteristics. It has good adhesion over bare metal, existing finishes, has excelent corrosion resistance, it has great fill and build qualities, and can be sanded. However the cure time on epoxies are longer. But where time is not a factor epoxies are a great primer.
Adhesion promoter: Ashesion promoter is mainly used when you are painting plastic pieces, ie. door panels, chin spoilers, interior peices, mirrors, etc... When you are painting raw plastic(plastic that hasent been painted before) You dont want to sand it with an agressive(a low number) grit of sandpaper or you run the risk of having mold release, that soaked into the plastic during the molding process, leach to the surface through the deep scratches and cause adhesion problems. And since you sand the plastic with a higher grit, meaning there will be less profile(a term used to describe the "roughness" of a surface prior to painting) for the paint to "grab" onto, it is a good idea to use the adhesion promoter to ensure your primer sticks to the plastic. The way it works is when you are ready to spray your primer, first spray a medium coat of adhesion promoter over the entire peice, and while it is still tacky apply your primer. It basically softens the plastic a little making it easier for the primer to bond with it seeing as how there is not alot of profile for the primer to "bite" into.
Now for some midcoats.
Single stage paint: Think of single stage as basecoat and clear in one. It was the thing to use before urethane basecoat/clearcoat paint came out, and now it is still used but base/clear is preffered by most. It is cheaper than buying basecoat and clearcoat, but it doesnt have the
uv protection that a basecoat/clearcot job will have. It may also be harder for some people to spray espicially in metallics because it is wet coats all the time, as opposed to medium coats of color when using a basecoat. Since you are spraying wet coats of your color it will be easier to get a run, and a run in mettalic single-stage means a repaint, but with a basecoat/clearcoat the base is medium coats with wet coats of clear, and any runs in your clear can be sanded and buffed out. If you get a run in a solid color single stage,
then you can sand and buff it out. Just not on the metallic, because the orientation of the metallics in the paint will be messed up during sanding and it will be extremely noticable. You can also put a clear coat over single stage, but if your going to clear your single stage, you might as well use a urethane basecoat.
Basecoat: This is what gives your paintjob the color.It can be solid color, pearl color(a solid with pearl mixed in it), or a metalic(solid color with metalics mixed in it) You basicly have two types of basecoats, a urethane, and a lacquer.
Since lacquer dries by solvent evaporation, it does not require a catalyst. It will also "re-wet" if sovlent is introduced to the dried paint film. A good example of this is sometimes when laquer base coats are applied over laquer primer sand scratch swelling can occur. Thats where the solvents in the color re-wets the primer that you have sanded to
get it ready for color and the sand scratches swell up and become visible. But Lacquer paint is far cheaper than ureathanes.
Then you have your urethane color coat. This is by far the easiest way to apply color and also the most forgiving way, since you are applying medium coats so there is almost no chance of runs in the color. Urethanes dry by solvent evaporation and must be topcoated with a
clearcoat to protect the color and make it shine, because basecoat dries to a dull finish. It also dries to the touch relitivly fast, so it is ideal for graphics where multiple colors or tape is used. Most basecoats are desinged to achive hiding and correct color in 2-3 coats and are
clean up alot easier than lacquers and can be sprayed at lower pressures than laqcuer, therefore decreasing the overspray and increasing the amount of material that actually goes on the car.
Pearlcoat: A pearl coat is different than a basecoat that has pearl mixed in it. It is applied over your basecoat and that gives your paint job another "coat" which is what a tri-coat paintjob is reffering to. Thats basecoat-pearlcoat-clearcoat. It is actually a clear basecoat( pretty much just a binder with no pigments in it) with a pearl mixed in it, so that when srayed ontop of your basecoat there is a layer of pearl over your color. This is what gives you your color change effects , and the more coats applied the darker and more pronounced the pearl becomes. So it is advised to do a let-down panel when reparing a car that has a tri-coat paint job. Thats where you paint a scrap panel with your basecoat and then spray one coat of pearl on the entire panel. Then mask off a small section at the top(like a 2 or 3 inch piece of masking tape) and then put another layer of pearl over the panel. Then mask off another section and put another coat on it, and repeat that until you have a color that you know is darker than you need. Then clear it and let it dry. Then you can take your let-down panel and compare it to your paintjob so you know exactly
how many layers of pearl needed to match your paintjob. Blending a tri-coat paint job is almost an art form, and take spractice to be able to get it right on your first try. Because not only are you haveing to blend your colorcoat onto the existing color, but you have to blend the pearl into it as well.
And remember the more coats of pearl, the more pronounced it is. So its a fine line between having enough pearl on your repair area and blending it onto the existing finish with out adding so much pearl in your blend area that the original finish now has too much pearl on it. But it is a very satisfying feeling
when you can blend tri-coats perfectly.
Metallic coat: Again its different than a color with metallics in it. It is sprayed over your colorcoat. The easiest way to explain this is think of a bass boat, and picture the enourmous piesces of metal flake you see ontop of the color, that is a metallic coat. It comes in many different colors and sizes
ranging from bass boat flake, to tiny metal flakes. With the larger flakes you will need a large needle and fluid nozzle to let the chunks of metal flow through the paint gun. It is also benificial to have a gun with a self agitator in it. Its a little mixer that is in some suction feed guns that keeps the metal flakes aggitated and thoroghly mixed in the paint, instead of spurts of little and lots of metal flakes. Also the larger the flakes the more coats of clear is neede to completly cover them and give you enough to sand and buff.
Kandy coat: Think of kandy as a clearcoat with color added to it, but doesnt affect the transperancy of the clear. You could compare it to what cough syrup looks like in a way. It is always applied over another basecoat. When looking a a kandy paint job you are looking throught the color of the kandy to see the your color/or basecoat. So it dramaticlly affects the color of your basecoat. It is also the hardest thing to spray, and you have to be in complete control of your gun mechanics, a perfect spraying gun you familiar with, and have
excellent painting discipline. It is extremely easy to get light and dark splotches and tiger stripes with kandy, because the more coats of kandy, the darker it gets. A true kandy(not just a translucent color) will turn almost completely black when enough coats are applied, wich makes it ideal for airbrushing because the shading possibilities are endless. In order to get a perfect deep as glass kandy job you have to apply it with perfect overlap, because anyvariation while moving down the panel will result in light/dark areas so you have to be perfect in your overlap, and a dead on consistant spraying path on the car. The only way you can get a truely perfect match on an entire car with a kandy, is to paint it with all the panels on the car and paint the entire sides as one panel. I mean you couldnt paint the car with the hood, fender, doors, and decklid off so you dont have to spray the jambs beforehand and expect a consistant film on all the panels. If you do end up with light or dark splotches or lines or any bad imperfetions, you cant just fix them with more kandy. Because remember more coats of kandy just means it gets darker, not it hides mistakes. If you have dark light areas anywhere on the vehicle and you want it right, you have to completley start over with the basecoat. Witch is why a
good looking kandy paint job is very expensive. Because your either paying for someone that can do it right and get it done the first time, or paying the average painter that may have to start completley over because he a couple inches off on a few passes on his last coat of kandy. Now material price just doubled, and he still may not get it right the second time, pretty much the reason a good kandy job is so expensive is your paying for the knowledge and expertise of the painter. But there is absoulutly no replacement for the beauty of a perfect kandy job, that looks deep enouogh you can just reach right into the paintjob.
Topcoats
The topcoat will be your clearcoat on a base/clear job, or when you are doing a single stage paint job since there is no clearcoat, your color is considerd your topcoat instead of being a midcoat. The clear is what gives your paint job its protection, whether it be uv protection, chemical resistance, or even protection from the weather, and its also what makes your paint shine and have that wet look.
Basicly you have two types of clear, lacquer and uerethane enamel. Painters dont really use lacquer anymore, because the urethane is a FAR superior product. Urethane has much better protection qualites and is a better uv shield, so im not going to get into the lacquer clear and just focus on the urethane since i would never recomend it to someone to use, especially if it is someone learning to paint. The urethane is just that much better and is alot more forgiving on the painter. You also want to use a high solids clear(almost all automotive clear is high solids now) because it will take less material to get your film build up you need. I will get deeper into urethane clearcoats when i get to the actual spraying part of the thread.
Wax on, Wax off
Amazing post Travis, This will clear up alot of questions I am sure. We need to get a write up about the steps of painting a body part with pics, equipment, ect.
+repz to you
Hey you should add Adhesion in the undercoat. If your painting something like wheels you would spray Adhesion instead of primer.. Just a thought.
ok, so we got a detailed write up on paints.... how bout a write up on how to make a cheapish temporary paint booth in out back yards? :) If Im gonna try to spray a car, I dont think I should do it in my driveway under the black walhut trees.... :)
Thanks for all the nice feedback sofar, and there will be A TON more info in here when im done talking about everything i want to mention.
nice write up travis_afx
Spray Adhesion instead of primer? Not familiar with that one. Pretty much use epoxy primer for most everything.
Yeah ill add adhesion promoter to the list, but its not gonna be how you are thinking 98. Im not really sure why you would use straight adhesion promoter when painting wheels instead of primer. That just doesnt make any sense to not use primer. The only time you really need adhesion promoter is when painting plastics, because you really shouldnt sand them reall aggresivly or you can cause release agents that have leached into the plastic during the mold process to come back to the surface and cause adhesion problems, and even then you would still prime it after the adhesion promoter and before the midcoats. If your painting wheels that are bare metal then an etching primer or an epoxy like gtr07 mentioned is needed, and if they are powdercoated then either sealer primer or again a nice epoxy primer.
I gotcha covered bro, ill add the paint booth in here tonight. Its a very easy booth to build and i have painted in several like it before with great results.
Again i really like the feedback from you guys, the more suggestions of what exactly you guys want to read about, the sooner i will get something written about it. With no suggestions ill just continue to write about stuff till i run out of things to talk about.
What a shitty write-up...
:shiftyeyes
Discussion Starter · #12 ·
Surface prep
There are alot of factors that will go into deciding the right way to prepare your surface for paint. Will it be a simple scuff and repaint, is there bodywork, are there things that need to be removed from the panel(moldings, door handles, mirrors, emblems,etc..)is it bare metal, is it raw plastic, is the paint your going over in good condition or is it delaminating, etc....
So ill try and do this in an orginized manner, but if i get confusing just ask and ill explain it better.
So preperation always begins with giving the area to be painted, whether its a whole car or just one part of a car, getting washed with good old fashined soap and water. After you have it washed and dried off you will begin to remove things that shouldnt be on it when painting,such as moldings, door handles, emblems, etc.... You must remove items like that so you can get a continuos paint film. When trim, moldings, emblems, etc... are not removed you are asking for trouble and will create an open edge around whatever you left on and just masked off.
The open edge often leads peeling of the paint film down the road, and is a big red flag that the car has been repainted. Things left on are also great places for moisture, dirt, and other contaminates which can come out later on in the painting process. So it would be in your best interst to just go ahead and remove anything like that in the begining and save yourself some headaches. One thing that cant easilly be removed that will cause a open edge is the reveal molding(the rubber gasket type thing around the outside of the glass) around the winshield and back glass. It is either made onto the glass or glued in with the winshield urethane holding the glass to the car. So unless you can easily remove and install those peices of glass, you will have to do something with the problem of the moulding touching the paint surface.
I DO NOT recomend anyone removing and installing the front or back glass that does not know exactly what they are doing, two reasons for this: 1. it is VERY easy to break the glass while cutting it out if you dont know how to do it properly, and 2. the windshield and the back glass are major sturctural componets in unibody cars and if not installed properly can result in major damage, injury, even death in the event of a wreck. The way to get around not removing the glass is to "lift" the rubber off the surface while painting and then laying it back down after the paint has cured. There is a thing called lifting tape, that is desinged to go under the moulding and it lifts up the rubber. Ive also used rope, speaker cable, and other various things. You can use pretty much anything you want, so long as its something clean and it lifts the rubber high enough up that the clear edge is completely under the moulding after you remove the lifter and let the moulding lay back down on the paint. Another good reason to remove mouldings and such is that while sanding one little accidental bump into it with your sander and it could be ruined. Also you need to be sure to remove any adhesive left on the paint after removing the item. This can be accmplished with some 3m adhesive remover and a little elbow grease. Alot of people swear by goo-gone, but i hve never used it so i cant really comment on it, but ive never heard of anyone having a problem with it.
So now that you washed your vehicle and removed anything you need to, its time to wipe the area to be painted with a wax and grease remover. You will need two seperate rags for this, one wet that you use to wipe the w&g remover onto the panel, and a dry one to wipe off the w&g remover. It will allow any dirt or contaminates to be "floated" above the surface in the sovlent, and that in turn lets you wipe off all remaining contaminates and the solvent with your dry rag. Work in small areas so it doesnt dry before you get to wipe it off. If it does dry before you wipe it off, you have to do it again without letting it dry. You never want to let freshly wiped on wax and grease remover just evaporate without wiping it with your clean dry rag first. Also change rags often if you have alot to wipe down, because if you are wiping on or off with a dirty rag, your are just moving the contaminates around and not actually removing them from the panel. Parts such as bumper covers may need to be wiped down with an additional step using an anti static solvent. If you skip that part the bumper will atract dust and dirt like a magnet ruining your paint job. If it is a raw bumper it is a good idea to wipe it down with a water based cleaner, beacuse it might still have mold realease on the surface and it is water soluble, meaning your normal solvent based wax and grease remover will not remove it, causing adhesion problems later.
........more surface prep to come later tonight.........
I saw what you did there Travis :shiftyeyes
Come in to one of my sections. It's on biatch :D
That's what she said :shiftyeyes
I had too :sorry
Discussion Starter · #17 · (Edited)
Now a little about different kinds of sandpaper and other things used to scuff or sand the surface to get it ready for paint. There are basicly three types of sanding media used in refinishing: wet or dry sandpaper, dry sandpaper, and scotchbrite(red, grey, and white). Wet or dry paper is used in wet sanding, it has a special backing paper that will not be affected by water and will be come more pliable when wet. Dry paper is used for dry sanding, and the various grades of scotchbrite is used when sandpaper is not needed to achieve the proper "roughness" for the paintjob or it just wouldnt make sincde to use sandpaper, like the underside of a hood for example.
Here are the common grits you would use and what they are generally used for(disclamer:different painters prefer different grits sometimes and these are my preference):
36 grit: A VERY coarse sanding disc, used when doing metal work. I would not recomend using this on newer cars, as the metal is so thin as compared to say the 60s and 70s
80 grit: Used when metal working, prepping metal for body filler, intial sanding of body filler(you should get the shape of your filler finished with 80 and the subsequent grits are used mainly to remove the previous grit's scratches)
120 grit: Used on your body filler to remove the 80grit scratches
180 grit: Final sanding of body filler removing the 120 grit scratches
320 grit: Feathering any paint edges around the repair area with a DA sander, sanding the paint around the repair area that will be primed with primer-surfacer(you actually want to go a little further than where you will be stoping the primer)
400 grit: Dry sanding primer surfacer
600 grit: Sanding any paint that will have primer sealer over it, wetsanding primer surfacer, blocking any small dings out that are shallow enough to be taken out with only sanding the paint, no surfacer.
1000 grit: Wet sanding any existing paint finish that will have basecoat sprayed directly on it(no sealer)
1500 grit: Wet sanding clearcoat
2000 grit: Wet sanding clearcoat, and removing 1500 grit scratches if it was used
2500 grit: Wet sanding clearcoat, sanding out dirt nibs, removing 2000 grit scratches if it was used
3000 grit: Final wet sanding clearcoat by removing 2500 grit scratches
Red scotchbrite: Scuffing paint that will be primed
Grey scotchbrite: Scuffing paint that will be based(no sealer)
White scotchbrite: Scuffing paint where a clearcoat blend is preformed
When you are wetsanding it is best to let your paper soak a few minutes before using it.
When wetsanding clearcoat add a couple of drops of dishsoap to help lubricate the paper and make the sanding go faster.
There are sanders called jiterbugs, that are like a da sander but has a rectangle pad and dosent spin, it is very useful in block sanding larger primer surfacer areas.
There are pastes(3m's is called sand-ez) that you can use when scotchbriting something and it helsp speed up the scuffing process and make the sanding more uniform. Before this stugg came out, painters used comet with their scotch brite pads getting a similar effect.
Try to avoid making vertical and circular sand scratches, always try to sand horizontally(or what i like to call sanding with the panel). Like on a door sand with strokes that go from the back to the front, instead of strokes that go from the top to the bottom or circular strokes. Horizontal scratches are harder for the naked eye to pick up. The only tim you should deviate from this method is if you are sanding body filler or primer surfacer, and then you would use a crosshatch method. Meanig sand in one direction for a few strokes, and then sand in the oppisite direction for a few strokes making a sort of x pattern. But alway try and finish with your horizontal strokes. If vertical and circular strokes are sanded into the clearcoat getting it ready to buff, those scratches are harder to buff out than the horizontal strokes.
Scotchbrite pads are a type of expanded nylon material that is impregnated with an abrasive. The scratches(or profile) left by the pads are more random than sandpaper because of the "open" consturction of the pads.
Here are a few do's and dont's of sanding i have picked up.
DO
Clean the area to be sanded with soap and water and then a wax and grease remover
Use a foam sanding pad when hand sanding to avoid sanding "finger grooves" into the finish
Tear or cut sanpaper sheets cleanly. A rough edge tends to gouge the surface.
Use a finer sandpaper when wetsanding as opposed to dry sanding because the wetsanding is more aggressive.
Use a guide coat when sanding to avoid over sanding and to help identify low spots.
Turn down the speed on your da sander near bodylines.
DONT
Use excessive pressure or speed when sanding to save time, because often times it will just mess it up and cause more work for you in the long run.
DO NOT i repeat DO NOT sand over body lines when block sanding. Take a body line on a door that is right in the middle for example. First block everything above the bodyline sanding down to, but not over, the bodyline. Then sand everything below the body line sanding up to, but not over, the bodyline. When you sand over a body line all you eill be doing is ruining the crisp like and causing more work for you. I like to take a piece of 3/4" masking tape and put it right on the bottom side of the line when im sanding above the line so i know exactly where to stop. And a piece right above the line when im sanding below the bodyline.
Discussion Starter · #18 ·
how to make a cheap paintbooth
Materials needed:
3/4" pvc pipe and joints
Duct tape
Flourescent lights
Filters
An Exhaust fan
First start out by making the frame out of your pvc pipe, You can make the booth any size you want, but remmeber the bigger it is the more exhaust power you will need. to fit a whole vehicle in it i like to have at least a 2-3 feet on each side of the car so there is enough room for me to bend down. and around 3-4 feet in front and in back of the car.
After you have settled on the size and have assembled the frame without using the pvc cement, it is time to cover it with your plastic. I have found the best thing for me to use is "painters plastic"
it lets alot of ligth through and comes in 12' X 400' rolls,
So start by taping one edger of the plastic to one of the corner pipes, from the bottom all the way to the top. If thhe plastic is to tall dont worry about that. Start stretching the plastic all the way atound the pvc pipe. Keep the plastic tight but dont stretch it so much it rips, you want it just tight enough to get rid off all the slack. When you get back to the corner you stared at cut the plastic and tape that end onto the plastic about 12" around the starting corner.
Now you need to make a door. How wide it is will be determined by what you are moving in the booth. If it is parts that you can carry in by hand you can make a smaller door. If you are making it big enough to panit a car just cut about 12" in from each corner. No matter how wide it is, the principle behind how the door works is exactly the same. You will want to cut a flap in the wall. Cut the both sides from the bottom to the height you need to move the parts in. When you wrap the frame with the plastic, if you will leave about 12" excess on the bottom you can use sand bags lying on top of the excess to seal the bottom edge of the booth and hold the bottom of the door closed. You can seal the side of the door a coule ways you can tape the seams shut or you can affix some velcro to the deges and use that to hold the door closed. If you tape a poll to the bottom of the door it makes it easier to roll up when ou need to upen the door, it will make opening it by yourself alot easier.
Now that the booth is built and the door is in we need to get an eshaust fan going. You can use just about any fan. I have used everything from box fans, the fans on the tops of ac units, squirel cages, etc..... The main thing to remmeber is to get enough air movement for how big the booth is. if all you can come up with is low poweed fans you might need a couple of them. At the oppisite end of the booth from the door, you will need to cut out an opening for the suction end of the fan. You can either build a stand for it to raise it up or just have it sit on the ground. After the hole is made and the fan is in place you need to seal the plastic to the fan housing using the duct tape. Then tape a filter onto the opening so the overspray gets caught and not blown outside.
Now anytime you have an exhaust fan you need a return air opening. This opening will euqal out the pressure in side the booth so the whole thing doesnt collapse on its self. So cut a hole in the wall away from the fan(s). You will want to take the return air filters for home ac units and tape them in the opening with the duct tape. You may need multiple return air holes depending on how many cfms your exhaust fan moves.
Now the last part is the lights. I like the double tube flourescent lights personaly. The more lights you have the eaiser it will be to paint. There is a couple reasons for this. One, the more light the easier it will be to see in the booth, and two, the more light bulbs you have the easier it will be to find a "light bar" on the paint surface. That is a reflection of the actual bulb on the panel which allows you to see how wet you are putting the paint on easier. You can also keep track of your overlap easier when looking at a "light bar". I like to have vertical and horizontal lights set up, again so i have multiple "light bars" to choose from. You just want to set them up outside the booth facing in. I use stands for my lights.
YES!!! My paint booth write-up that was forever lost :woot
1 - 20 of 30 Posts
