1 - 6 of 6 Posts
ok, maybe using the word diving is a little harsh, but when I press the brake pedal at highway speeds my car tends to push to the left. and when I let off the brakes it wil pop back to the right. I have replaced the pads, rotors, calipers, brackets and rubber hoses on both sides in front. bled and rebled the system. its better than it was when I forst got the car, but it is still there and in rain at 0300 it makes for some sporting driving when I have to hit the brakes quickly..
What else should I look into? suspension bushings? Car has 180K on it. I know some bushings have been replaced by the PO, but I doubt they all were. debating on getting new shocks an struts for it, just because of the mileage. Im sure that wouldnt hurt. Just not sure what I should be looking at for this braking issue.
At 180,000 miles I would say every part on your front end is pretty much 'worn out'. I would for sure replace the front struts and check your front wheel bearings. A loose wheel bearing 'could' cause this but don't 'over tighten' them, that would really mess them up :( Check your front 'strut mounts' also :)
Put rebuilt/new calipers on the front. Your problem is most likely the right one hanging up. You can hone the cylinders and put new seals in them but its a pain. Could be same problem with the rear right but not as severe a pull. Suspension may cause a terrible ride or pull to one side in normal driving but would not normally cause the braking problem you have.
already put new calipers, hoses, pads and rotors in the front....
when I hit the brakes I can feel the steering wheel get pulled left which leads me to think it is in the front. I plan on ordering all new bushings and socks/struts in about a month. I also need to look at the steering rack as my steering feels odd. its kinda firm, and dosent return to center. thinking the racks valves may be slightly plugged. I can get a new one from CJ for a couple hundred.
So Im hoping with teh suspension/bushings/rack this should be solved... maybe...
Worn ball joint most likely. Could be worn hubs, tie rod ends, upper or lower ball joint, etc.
Get it checked out. A good alignment shop should be able to tell you quickly.
1 - 6 of 6 Posts
