1 - 7 of 7 Posts
the abs light on my 96 gt started randomly turning on then back off today, it did it maybe 10 times. the fuse isn't popped and the car is breaking fine, should i worry about it? I just put a 373 gear in it but i don't know if that would effect anything...so basicaly should i worry about it and if i should where should i start?
thanks,
-calvin
check brake fluid levels, and your pads.could be time for new ones
Yea, there's a level sensor that monitors the brake fluid level but normally I believe that turns on the brake light, do you have different front and rear tire sizes?
You probably have an abs sensor going out or dirty.
same front and rear tire size, pads and fluids are good, probably just a censor i'm not gonna worry about it too much, it didn't even happen today
Yeah it could just be a bad sensor. My coolant light always pops on and off at random times. Il hit the break pedal and it will turn on then il shift into 2nd gear and off it goes lol plus i know my coolant system is fine. Everything works and the car doesnt overheat. Our sensors are 15 years old now so id imagine they would start getting gunked up or dirty and start failing even from pure old age.
just as an fyi for anyone looking at doing these sensors - theyre expensive. like about $100 for each corner. and dealer only parts. be careful when dropping down or working on the front or rear ends of your cars if you want to avoid breaking these.
1 - 7 of 7 Posts
