21 - 25 of 25 Posts
Discussion Starter #22
Imbalance with the pins are welds isn't an issue if they are evenly spaced, plus the diameter of the circle of welds and pins is so small that they wouldn't effect the balance even if they weren't evenly spaced.
I was wrong about TFS recommending to weld or pin the gears, what they say is when using these gears on high HP builds they recommend having the crank machined for a full length key.
That wasn't an option for me so I welded and pinned.
Discussion Starter #25
I will be over 500rwhp so I guess I should pin and weld.
21 - 25 of 25 Posts
