1 - 20 of 22 Posts
I got a really good deal on a 97 GT with no motor and I was wondering if you guys could offer up some advise. Since there is no motor, I was wondering which way would be the best bang for the buck. I've been torn between a stock 96-98 bottom end with the PI heads and intake or a 96-98 4v motor. Whats your thoughts?
6 Time ROTM Loser!
well if you could get a 03/04 cobra engine, get that. If not, still get a 4v. Or do what sharkbait did and get a 5.4L and put a blower....
lots of different options, just have to see what your final goal for the car is and how much you want to spend.
Ya the 03/04 motor would be great but I dont see that happening for any kind of cheap. I'm trying to do it as cheap as possible while still being able to run good.
What ever you decide to do. Just dont do a carb'd hack job. Stick with Fuel injected like a 97 is meant to be.
Arent the 99 and up more HP?
Does it still have the stock ECU and wiring harness?
The wiring harness is stock and the ECU already has a chip in it for a PI swapped 2v. The car came with long tubes for a 2v as well. To switch to a 4v would be a little more money. I'm just wondering if the increase in power will be worth it.
Sarcastic Sally
A Mark VIII can be "kinda" pricey with all the lil ins and outs you have to buy but def. gives you more potential for hp/tq than a regular 4.6 2V PI or NPI. If nothing else do a 4.6 2V PI swap forge it and slap a FI on it...A 5.4L swap with a blower like Sharky's can be pricey as well, while 5.4 are cheap and readily available certain parts to make it fit with your stock hood i.e. intake manifold can run you close to 500. IMO Sharky got lucky with finding his parts and he has a good bit of mechanical know-how(not saying you dont)...
Well if you go 5.4.
You can get a motor for about 1000 or so with low mileage. The kicker though is the HPS intake...which costs around 800....and your not finding a used one lol. Seeing as mine was sold before it went up for sale.
Everything else though is fairly straight forward.
Sarcastic Sally
If I could go back and do it over again I would have skipped the Mark VIII build I have goin on and just forged my 2V and gone FI...Still could go that route but I have the engine already and so many new parts, it would be a bitch to sell...
Well if you go 5.4.
I just saw a topic on The Corral saying that with a little bit of fabrication, the new 5.0 and Boss intake could work.
Discussion Starter #17
I can get a 96-98 Cobra motor for $700 from a local shop. I don't know what kind of shape it's in yet though. Or I can get a NPI 4.6 from a junkyard for $150 and then have to rebuild and piece together the PI swap.
King Trashmouth
4v>2v if theres an option, but def pi swap if you go 2v...
I wish thats how I knew too :( wicked....
Don't forget 3V is an option, but for the most part I think the MKVIII swap is easier and cheaper.
And don't go getting too jealous, I've got the motor torn apart (waiting for my cams to get here!:mad:) and no T56 or fuel tank yet.
1 - 20 of 22 Posts
