1 - 20 of 55 Posts
MM's official Chevy guy
u/d pullies
or start saving for somthing biger (i.e. s/c, turbo, power pack, or built moter)
!!!!! good idea but i plan on staying NA or going with a positive displacement SC but thats down the line a bit...
mmmm pullys, would an overdrive on the alt decrease the power gain i would see from the underdrive pully? i have a big sub but i may take it out or not play it with the lights on or something lol
then start saving up for a power pack or built moter.
but you could look in to trany mods, aluminum drive shaft.
a over drive will stille net you a gain in power to the wheels just not as much, and it will keep you from under charging.
also if you are gana go s/c u/d puillys are nota good idea.
eventually i want to get an m112 adapter from SSMS and run a kb at 9psi or so. so is there anything a can do before that? cam, lifters, springs, and pushrods and what not?
ya build your engin, forged internals ect. i know the stock botom end can handle 9 psi with out a problom, however i don't think you will be at that for long, when a simpe pully swap and tune will inmprove it nicaly.
als oas i said tranny and drive line mods.
do you have a auto or stick
Discussion Starter · #11 ·
i have a stick, and the clutch is approaching its last few months, so i was looking into a new clutch and possibly an aluminum flywheel but i havent really decided on anything yet.
a aluminum fly wheel is very good, frees up some good hp and a aluminum drive shaft also helps with that.
Discussion Starter · #13 ·
yeah, do you have any recommendations for flywheel and clutch. and does anyone make an aluminum drive shaft for the v6 or is that some i need custom made?
chris just got a aluminum fly wheel so you may want to ask him
and the gt drive shafts fit our cars as well, i think all you need to do is swap the yoaks.
Discussion Starter · #16 ·
how noticeably do the sub frame connectors effect the cars handling? and do the have bolt on ones or is it just weld them on?
they have both for subfram conecters
Doc
sfc are a VERY good mod. you will notice them easily.
your handling will improve pretty damn well.
I believe that it's a must on any mustang.. especially verts.
also.. weld them on..
+1 welded ones will give you a better result
Discussion Starter · #20 ·
alright. i dont know how to weld myself but i can find someone to do it... looks like its lowering springs and subframe connectors for now.
1 - 20 of 55 Posts
