1 - 15 of 15 Posts
So I am running thirty pound injectors and a calibrated mass air new fpr from holly and a holley pump trickflow top end and new rotating assembly. The thing is I still have the stock heads on and I am just drowning them. What I can't figure out is the right fuel pressure the run this and where should timing be set at
Yea that's where it is now and seems to run the best but as soon as I get stuck at a light it loads up and runs like **** I tried getting new plugs and picked up new 10mm wires the dizzy is new could I need to get hotter plugs?
I should prolly get a set of 205 heads too lol I just cheap but it shoul work if tuned as is I prolly just get some heads first cause its getting to be that time of year where its to shitty out to drive anyway
Ill give that try and be prepared for that fpr to break and I would be using my twenty four #'rs but I traded them used for a new set of thirties I couldn't pass it up ill turn it down a little and keep u guys updated thanks for the help
it might help a little but your still going to have driveability problmes out the ass with that setup without forking out the cash for a tune which would be pretty gay also being stock heads/motor with large injectors and a maf upgrade.
I'd honestly go to the junkyard and pull the stock meter and injectors for $20 and install them until you save up for more mods just a thought. fyi stock 19lb injectors are good until the 280hp area
you prob need a tune with those huge injectors
LOL 30s are not huge by today's standards We run 83s lol..
But like said I would find some stockers to throw back in there till you need to move up..
1 - 15 of 15 Posts
