1 - 20 of 30 Posts
I am running the stock KB unit, upgrading would be a good idea. I am looking at the ones for terminators.
The Termi might be a better way to go.
You might have package issues with the GT500 exchanger, and it does seem to be a bit overkill.
Don't forget about the pump and resevoir packaging too..
Ya i threw up the GT500 exchanger as an extreme. i was also looking at the upgraded termi ones as they are more realistic for my setup. But i do like the electric fan idea and may incorporate a single 6 inch or somthing with key on power to help out.
Im using the LFP Heat Exchanger.
If you measure intake temps or inlet and outlet sides of the exchanger did you notice a difference?
i would go with the killer chill as well. but if you want to run a good system with a heat exchanger i would run a large trunk tank with a upgraded heat exchanger and pack it full of ice when your at the track.
Tis true
I did not persoanlly but the guy who had teh kit before me did and noticed around 30* drop just from swapping from a factory 03 cobra HE. He was seeing 118-124* IATs. Mine on the dyno was seeing 110* IATs. I also run some water weter in mine. My HE never gets too warm, its usually hard to judge even to the touch.
Discussion Starter #15
If the time ever comes this is what i may upgrade to. although mine isnt much smaller then that.
I would love to find an actual intercooler upgrade.
that seems like a really good price for such a large HE with the drain petcock too... shifting my attention to this product now
I actually found it while I was on a diesel site. I book marked it because its about half the price of other quality heat exchangers.
I wanna measure mine now to see if its any larger. and worth switching to..
and not to thread jack, but for you KB guys, this is what i have in the works to not only help IATs but to allow a hell of a lot more air in.
Is that Daves(turbocooker)? How Much?
Discussion Starter #19
Willy what intercooler are you using now?
Id really like to see what that inlet can do
i am still running the stock cobra h/e and tank, to help keep my iat's down i put a drain on the tank so i can drain water out and add ice.
i used parts of my gardan hose stuff to make it
1 - 20 of 30 Posts
