If the alignment has never been touched before then he may have been talking about the rivits that are in the oem casher camber plates. they would have to be removed to make any adjustments.
in order to align at all you need to drill the rivits.If the alignment has never been touched before then he may have been talking about the rivits that are in the oem casher camber plates. they would have to be removed to make any adjustments.
I believe the closer you get to an 1.5" drop the more cc plates would help.. after the 1.5" drop you def need them but each car is a little different
you should never use an impact gun on a strut that you plan on re-using, it wears out the rubber seal in no time at all.An impact wrench will make the first part of that MUCH easier.
Isnt toe what keeps the car straight at speed?you use the tie rods to adjust toe, you still have caster and camber to worry about as well.
caster can also effect the car going straight.Isnt toe what keeps the car straight at speed?
That's not entirely true. A large amount of positive caster will increase your scrub radius, which will increase overall tire wear.toe/caster/camber can all cause a pull. caster is the only angle that cant effect tire wear
right, but camber doesn't effect or cause a pull as bad as caster.toe/caster/camber can all cause a pull. caster is the only angle that cant effect tire wear
Caster's only going to cause pull back to center, though.right, but camber doesn't effect or cause a pull as bad as caster.
and when one side has say 2.3 degrees of caster and the other has 1.1, it will cause a definite pull because the 2 sides aren't pulling to center the same amount.Caster's only going to cause pull back to center, though.
