1 - 7 of 7 Posts
The other day, I was out with the car, and once I hit 65mph, I felt a noticeable vibration in the drive line of the car. I can feel it through the shifter and bottom of the driver seat. Only occurs about 65 mph and above. The car has gone on jackstands and the drive line appears to be tight, the rear tires are not cupped nor have they separated a belt. There is no weird noises and performance hasn't been affected, but I'm still nervous to get on it! Any ideas?
!FACEPLATED!
Have you done any rear end work recently or had the drive shaft off?
Better than Drugs!
Wheel weight fell off of one of the wheels. Check it.
The car has gears, and tape weights for the wheel weights. All of which are intact, unless they double stacked them and half fell off. I'm at a loss. Everything feels tight, and was re-checked. I might pull it apart and put it back together. Who knows. But thanks for the help gents! I double check everything!
!FACEPLATED!
before you pull everything apart, unbolt the ds from the pinion flange, rotate it 180* and put it back on. Try that and see if it gets any better
  • Like
Reactions: 03OFP
!FACEPLATED!
Did you give it a try yet?
1 - 7 of 7 Posts
