1 - 7 of 7 Posts
Hey everyone. My alternator on my 03 gt isnt putting out any voltage. I've checked all the fuses in the interior fuse box and the one in the engine bay, replaced the alternator, had it tested, and everything has checked out fine. The engine is grounded to the chassis, the alternator is grounded, I dont know what it could be at this point.
Check that all the pins in the connector are seated. I had the same issue a while back and thats all it was.
Sent from my iPhone using Tapatalk
No issues with the connector unfortunately. There aren't any other fuses outside of the fuse boxes are there?
Not that Im aware of
There is no voltage coming out of where that plugs into. I cant find anything coming out of the alternator anywhere actually.
Check all your grounds and recheck those pins to see if they’re seated all the way. I wonder if the ccrm could cause this.
1 - 7 of 7 Posts
