1 - 8 of 8 Posts
When installing an aluminum D/S, do you have to adjust pinion angle any? Im wanting to buy fixed length LCA's, didn't know if you had to adjust for the one piece D/S. Any info would be appreciated.
It's a darn good idea to at least check the angle. Especially if you're lowered.
Made in U.S.A.
If you're lowered than yes you need to get an adj. UCA.
If you're not lowered than you're in good shape.
i agree with nastystang. you wouln't be adjusting the pinion angle with the lowers anyway, you just do it on the upper where you only need to make the adjustment at 1 point .
I'm currently at - 1.5 degrees. No shake or vibrations and all is well !!
1 - 8 of 8 Posts
