1 - 20 of 33 Posts
Come at me bro
For me the only real gain is I lost a ton of vibration issues (mainly at highways speeds) and its 9lb's lighter!
didn't notice anything else though...
Free Mouth Hugs
+1
I have a ford racing one, I dont know personally but I have "heard" they help rev quicker. :dunno
Didnt make my car faster, made it cuise alot smoother though, so for that its worth the 100 bucks for a new one
thanks i was wondering about aluminum driveshafts also.
I put one on both my stangs,91-95. I had a bad vibration problem on my 95 and had it looked at but nothing was found. They installed new HD U-joints and it was still there. After I got a good deal on a used one from a buddy I installed it and vibration gone. Turned out the stock shaft was bent, don't know how. They do help with quicker rev's. Put and aluminum flywheel also like I did and you'll see what I mean.:yes
Same reason I bought one, my stock one was vibrating bad and I got an aluminum one used in great shape for $100. No more vibrations. I noticed nothing performance wise but the aluminum one is about 5 pounds lighter.
yea i have LOTS of vibration at highway speeds prolly 65MPH+ i think its my driveshaft, but i deff could imagine quicker revs, you will prolly have to throw a lightned flywheel to really notice a difference, but i hear the aluminum are balanced better so i think its worth it... supposely every pound of rotating mass u take out is equal to dropping 6lbs of unsprung weight. so if the driveshaft is 6lbs less than stock thats like taking 36lbs of junk out of ur stang...its gotta help
Discussion Starter · #11 ·
oh I see it needed to be rebalanced
I guess for all the new people that have plans on getting it. I say "say good bye to doing a wheelstand in the future
how much power are you gana put to a alum. driveshaft before twisting and breaking?
Any time you can cut down on rotational mass it's a good thing.. the frpp ones are larger OD wise, lighter, stronger then any stock shaft so it's a win win all the way around except for the price if buying new. They've tripled in price over the last five years
i've made 403 to the wheels in my turbo car and it had a frpp aluminum ds no issues but switched to a t56 so required a different length shaft so the frpp went into my dd 88 hatch which has every bolt on minus power adder.
well hopefuly i will be safe then, im looking to build about 500 to the flywheel. but im going to have a good suspension setup also. im sure i will break the stock axles before breaking a drivehsaft lol
not really adding anything new here, I have one in my 94 gt and I definately say they are worth it. Like flyin ryan said , anytime you can cut rotational mass, that is GOOD thing, and the car revs faster. I say do it.
1 - 20 of 33 Posts
