The heads I am looking at are complete with valves and springs.did you have those valves put in ? and you might have clearance problems if your valves are 2.02/1.60 and the X does have a lot of lift.(for a motorsport cam)
They are ProComp HeadsWhat heads are they?
Wouldn't recommend using the outdated X cam if you are buying a brand new set of heads.
Max lift #'s have nothing to do with PTV clearence. The piston isn't close to the valves when max lift occurs.
To answer your original question, the 2.02's with the x cam will not clear. Always measure.
OH boy stay clear from those headsThey are ProComp Heads
Here are the specs of the heads:
210cc Intake Port
75cc Exhaust Port (Port raised .25 inch)
60cc Combustion Chamber (Higher compression than stock heads)
2.02/1.6 Super Duty Stainless Steel Valves
Dual Valve Springs 120LBS installed height, 390LBS open, .650 max lift, coil bind @ .795 lift
Chrome Moly steel race retainers
Chrome Moly steel superlocks
ProVITON extreme valve seals.
No I didnt yet. Why?please say you didnt buy those heads..
What would be the benefit of the Floo Tek heads over my GT40P heads?I have put two sets of these on cars, one 302 and one 331, and they seem to be holding up very well, but you need to swap out the valve spring. Very good head for the money and for me, made a few hours away from here.
Tri-State Cylinder Head - Chevy, Ford, Small Block, Performance, Aluminum Cylinder Heads
Pretty sure those are pro comp heads assembled by tristate.I have put two sets of these on cars, one 302 and one 331, and they seem to be holding up very well, but you need to swap out the valve spring. Very good head for the money and for me, made a few hours away from here.
I agree they are pro compsPretty sure those are pro comp heads assembled by tristate.
