1 - 6 of 6 Posts
I still need a clutch for my fox, I did some research and decided on a dual friction centerfoce stage 2. But after looking at the cyber deals, would any of you recommend the ones they have on sale?
I Have A FLATULENT Butthole.
I ordered the exedy Mach 400 today
Sent from my DROID RAZR HD using AutoGuide.Com Free App
Only have used the ram of that list. Never heard of the other. Currently have a centerforce dual friction. Ram was on a bolt on car, worked good. Current Centerforce was behind a 500rwhp sar before third gear ate it's own teeth and was fixed. I did a AOD/T5 swap with my buddy who had this prior. Clutch and flywheel still actually looked good so I reused them.
I'm a big Exedy fan, personally. Those clutches hold some serious power, have a great pedal feel and take a good amount of abuse. They're also pretty fairly priced when you look in comparison.
That being said, the Centerforce clutches have been a standard for quite some time. They were even making the "King Cobra" clutches, too. You'd be really happy with a Centerforce.
Either way you go, you'll be really happy. I had a 90 hatchback with the Exedy Stage 2 plus the fully adjustable cable, quadrant and firewall adjuster. It was the best feeling clutch I've ever driven in a 79-95 5.0L. I had it set perfectly for my taste.
That being said, if you are going to add a little bit more power down the road, the extra torque capacity of the Stage 3 is a bonus. Stage 2 is for bolt-on Foxes, maybe even a cam and manifold. If you're thinking of changing heads, going long tubes or any sort of power adder - the Stage 3 is where it's at.
Hope this helps!
Chris
1 - 6 of 6 Posts
