1 - 4 of 4 Posts
Well my car stranded me today. 95 Gt. Turns out the alternator that was less than 6 months old was burnt up, and it killed the battery as well. Replaced both of those, and the new alternator is only putting out 30amps at idle. I read that it should be around 45amps. Also it idles a bit rough. Putting out 13.7 volts.
The car has an aftermarket stereo, and it has an alarm but it is disconnected from power.
What could be causing an amp draw?
might wanna do a voltage drop test,also depending on where you bought your new alt it could be the cheap internals in which do not put out the amperage they should
Ok, new symptom. The brand new alternator I just installed today is now fried and not producing power. Immediatly after I installed the new one the volt gauge on the dash would only read on the N, at one point it shot up to the R and stayed for a min or two, then dropped back to the N, and now its barely in the normal range and falling. When I pulled in just now my headlights and gauges were barely working.
1 - 4 of 4 Posts
