1 - 9 of 9 Posts
I have a 92 gt that I just did heads/cam/intake on and its all back together. I put 24lb injectors with a maf calibrated to them. The car was idling well the other day and went to move it into the garage and it just wants to idle at 2k. Its like something went out on me.
Any ideas what would cause this idle to change like that? I put a new idle air motor on it, didnt fix it. But when I unplug the idle air it changes the idle and most of the time will not stay idling.
It is running rich now too.
Any ideas would be much appreciated.
Did you check for codes? Also, what maf are you using?
Its a granatelli, cant remember the part number. I will have to double check the part number but was ran with 24pounders before.
Did not check codes yet. I dont have a code reader for obd1.
I hear that the tps can go out and cause this?
Thanks for the link!
Do you have the factory reset procedure in a link? handy, if not no biggy I am sure I can find it.
get you some of that
With all the mods get a tune it needs it and it will solve all your problems. Just make sure they know how to tune a foxbody there is an art to it.
1 - 9 of 9 Posts
